Release 2: 10.7.2 New Features and Addressed Issues
New Hardware Support
There is no new hardware supported for Release 10.7.2.
Table 1. New features in 10.7.2
Feature ID New feature Description
HOS-18946 AFC: GA Ready AFC Solution AFC is now supported on IQ Engine specifically for the AP5050U & AP5050D. AFC support is a requirement for Standard Power use for outdoor 6 GHz radios. The AP must coordinate channel and power availability from an AFC SaaS database before transmitting.
Thread router—Fix mdns advertisement when using non-default vlan We resolved an issue with mDNS advertisement when using non-default VLAN.
Table 2. Addressed issues in 10.7.2
Issue ID Description
CFD-9256
(02740906, 02762111, 02858831)
IQE: ASCOM iP62 randomly drops calls on roaming failures.
CFD-10640
(02903895)
The AP302W Kernel and Hardware Watchdog crashes on 10.6.5.
CFD-10962
(02926088)
Universal APs: Beacons do not show updated WMM QoS values for Contention Window Min and Max.
CFD-10995
(02901029)
The length of R0KH-ID in the Reassociation Response is incorrect, causing an R0KH-ID mismatch and some clients to drop down the connectivity accordingly.
CFD-11040
(02929452)
[IQE] Delta config push issue sometimes causes ACL to not work as the AP IP-policy (firewall).
CFD-11050
(02921799)
[IQE] AP510C 10.6.6 getting "ah_auth" crash, often causing the client to reconnect, due to 32 characters limit.
CFD-11167
(02938970)
PPSK self registration: Security vulnerability with captive portal solution.
CFD-11169
(02918590)
Improper redirect—PPSK Self registration.
CFD-11304
(02946092)
AP5010s unable to establish a CAPWAP connection until after reset.
HOS-20556 We increased the Dynamic Packet Capture file size from 50kb to 100k to address a scenario were captures were not showing up.
HOS-20803 We resolved an issue with Client Monitor 2.0 and Dynamic Packet Capture not working for WPA3-ENT protected SSIDs.
HOS-20992 We resolved an issue with the AP5020 ETH0 Wired speed showing as 10Mbps instead of 10Gbps on the D360 Wired Interface.
